PostPosted: March 15th, 2018, 2:48 am
When I fire up the gallery using 1.9.10, I receive the following error message:
"Revocation information for the security certificate
for this site is not available. Do you want to proceed? Yes No".
PostPosted: March 15th, 2018, 5:03 am
For me works fine Dean.. Seems that depends on your browser , security settings.
I will pass your report to Tony though..
PostPosted: March 15th, 2018, 5:24 am
Note I do not get that error when using my browser to view widgets in the gallery on the site.
It does not appear to be a browser specific issue as I wasn't using the browser to view the gallery, in fact, my browser was off when I opened the gallery from the widget menu. The widget engine may well use a default browser to display the gallery but that is unknown to me as I don't have the code to view.
What that indicates is there is an SSL certificate issue with regarding to revoking a certificate when that specific function is used from the xwidget engine. I have never seen that message anywhere before so seriously I doubt it is a settings specific message. Much more likely to be a fault with the SSL certificate, as it seems to point out.
When my default browser IS running then it is firefox based and so if there is some sort of connection between the xwidget engine and my default browser - and I am receiving such a message - then others using Firefox browsers may well be receiving the same message, so it is seriously worth taking note of.
