PostPosted: July 18th, 2017, 10:03 pm
When I edit the widget (weather using accuweather engine), the following error came up!
No argument for format '%)'
It appears when I edit the weather part and click the "Add tag" then the above message came out!
If I change the engine from accuweather to cnweather, this error disappear!
I also checked the previous version 1.932 and it works OK.
PostPosted: July 19th, 2017, 1:36 pm
Try to close the designer and try again or even restart xwidget. I never had this problem..
More info about when you receive the error..? Windows version..?
PostPosted: July 20th, 2017, 5:48 pm
I used the translation file (Japanese.txt) provided by Mr.Tilt (the same author of Japanese translation , http://tiltstr.seesaa.net/article/45153 ... ml#comment).
I found this error occurs when I use the above file, but this error disappears if I use the Japanese.txt file included in xwidget itself.
But this is old for xwidget 1.96, but actually it can be used for 1.96! Now I used this old file.
I think that the translation file is just a reference file and it should not affect the program behavior, and there must be a confiliction in the internal processing.
P.S.
This error occurs when I edit the items related to weather engine (accuweather), and not occur for other engines !
