PostPosted: May 24th, 2017, 2:09 am
can someone make a clone of this weather widget if possible? thanks..
http://www.phonearena.com/image.php?m=A ... 34&popup=1
PostPosted: May 24th, 2017, 4:23 pm
Here :)
viewtopic.php?f=11&t=6694
(For the Android version download the widget directly from the app's online gallery. Give me the time to do the necessary adjustments)
Please next time post to the right section -> Android
viewforum.php?f=19
(the topic will be moved there after your reply)
