 Post subject: Search function?!
PostPosted: January 24th, 2017, 8:33 pm
I just installed XWidgets and wanted to select some widgets...from the 1000+ available. However, this is nearly impossible without a search feature. Am I missing something?
Thanks
 Post subject: Re: Search function?!
PostPosted: January 25th, 2017, 12:40 am
Hello pcutter. There is no search field for the pc online gallery. Only for Android.
You need to click on the 'Show All Widgets...' on the bottom of the gallery and navigate through pages.
If these widgets are mine you can search through my profile on DeviantArt
PostPosted: January 25th, 2017, 6:22 am
It is appalling that here is no search function, I have raised it with Tony to no avail.
Users browsing this forum: No registered users and 214 guests
