 Post subject: 2.0 Feature Suggestions
PostPosted: December 13th, 2016, 3:58 am
- Ability to add data to the clipboard without needing a command line execution.
- Have the new installer add the registry keys to let HTMLPanel use the new IE renderer out of the box (I have the method documented here)
- Improve HTMLPanel so clicks are registered in Win 10 Anniversary edition
- Improve HTMLPanel so it no longer stays on top of other Xwidget elements in the same widget
- Give Widgets a Z-order you can save in settings so they can remember which widget is set to be on top of another widget when you have multiple ones set to always on top.
PostPosted: January 19th, 2017, 1:11 am
+1 for - Improve HTMLPanel so clicks are registered in Win 10 Anniversary edition
