It is currently October 23rd, 2026, 4:09 am
PostPosted: April 28th, 2016, 11:28 pm
my OS is windows 10 i seem to have a bug with Xwidget , i have 2 monitors and when i game i change primary desktops from monitor 1 to monitor 2
the widget i have displayed on the second monitor does not transfer its self when switching primary and disappears all together yet in the option to manage widget it says its still running
what i would like it to do is when i set my desktop as primary on monitor one my widget is displayed on my second monitor which is how i have set it up and when i change primary desktop to the second monitor instead of the widget disappearing i'd like it to switch screens to monitor 1 so in a sense everything i had on desktop 2 will be transferred to desktop one when i change primary screens and set back one i change back primary screens
maybe a simple fix would be allowing widgets to choose or select which monitor to display on 1 or 2 as default locations
PostPosted: May 20th, 2016, 12:40 am
How have you set up your monitors? Extended display? Mirror mode?
PostPosted: May 20th, 2016, 1:29 am
Extended , no point in having mirror
Users browsing this forum: No registered users and 263 guests
