PostPosted: February 20th, 2016, 3:47 am
I noticed that the weather from Google works better for me than the weather from Accuweather. I would suggest to add Google as a provider of the weather, but that was the choice.
Accuweather and Google
As for the location it MUST be Accuweather because it shows accurately!
Weather from Yahoo does not work at all!
Tony?
Jimking?
What do you say?
PostPosted: February 20th, 2016, 10:00 am
I can't tell which weather provider works better, because it also depends on the country. But having more than one choice for the weather, yes I totally agree with it.
PostPosted: February 20th, 2016, 2:00 pm
So, in terms of choice of supplier weather. Of course, apart from Accuweather and Google would also add Yahoo
PostPosted: August 14th, 2016, 5:39 pm
yahoo weather stopped working because they require oauth now.
Users browsing this forum: No registered users and 247 guests
