 Post subject: [BUG] Update weather
PostPosted: January 12th, 2016, 9:16 am
I tested a different update interval. 15 minutes, 30 minutes, 1 hour.
No matter what I set, it is not working.
Example:
Last updated according to Accuweather server is 17:05
The time now is 18:15, and nothing happens.
PC seems to work fine, because I have now update of 17:55
 Post subject: Re: [BUG] Update weather
PostPosted: January 12th, 2016, 9:22 am
It's 18:20. Just now only be updated at 18:05 on the server.
I would add that the updates are Accuweather server every 10 minutes.
Example:
17:05, 17:15, 17:25 (time 17:26), 17:35 (time 17:37), 17:45 (time 17:46), 17:55 (time 17:56)
Users browsing this forum: No registered users and 174 guests
