PostPosted: June 16th, 2015, 11:21 pm
Yesterday evening and today there are any problems with downloading weather with Accuweather.
Can anyone confirm if it's just in me is wrong?
PostPosted: June 17th, 2015, 4:42 am
Weather works for me on PC and Android..
On pc try to click on the weather widget and then press F5 to reload.
PostPosted: June 17th, 2015, 7:53 am
But I guess the problem with Accuweather. It may be in my country.
PostPosted: June 17th, 2015, 8:39 am
Maybe... Try what I told you though to see if will work..
PostPosted: June 17th, 2015, 11:37 am
I have tried is not working.
Guilt is on the side of Accuweather in my country.
