PostPosted: June 1st, 2015, 11:13 am
there is a bug in datetimecore1 regarding DST in PC editor. Instead of adding 1 hour because of DST, when you check the field it deducts 1 hour from the time zone.
Can someone check this?
PostPosted: June 1st, 2015, 1:27 pm
Read this:
viewtopic.php?f=3&t=2213&p=2756&hilit=Timezone#p2756
PostPosted: June 9th, 2015, 4:21 am
It becomes quite difficult for us to find your issue because a majority of us live at timezones where DST is not observed.
