 Post subject: Winamp with Player bug
PostPosted: April 24th, 2015, 1:35 am
I have an issue using Winamp with any player widget.
The player does not refresh the next current playing song for some reason. It stays on the previous track.
I can fix this by mousing over the widget and hitting f5. The correct now playing song title is then updated correctly.
I have tried many things to try to fix, all to no avail.
Pls see this thread for history..
viewtopic.php?f=8&t=5581
Cheers, Pete
PostPosted: April 24th, 2015, 3:55 pm
I removed all plugins and had no issue as yet.
I am trying to figure out which plugin may be causing the error.
So at the moment this is looking like it may be a Winamp 3rd party plugin issue.
Will update when I find...
Cheers, Pete
PostPosted: April 24th, 2015, 10:30 pm
Still testing.
Cheers, Pete
PostPosted: April 25th, 2015, 4:36 pm
Could the issue be that the icon for media player core shows a windows media player icon?
Also when I add the player name tag in binding core area it shows "windows media player" instead of Winamp for current player.
Maybe it is getting confused with WMP and Winamp when looking for next song?
Does anyone know if the player should work with Winamp or was it specially designed for WMP only?
Cheers, Pete
