 Post subject: 64 bit
PostPosted: April 19th, 2015, 11:33 pm
We need a 64bit build of XWidget and XLaunchpad. Somethings like dragging-and-dropping, media player integration (PlayerCore) are heavily broken on 64 bit systems
(Took a 64 bit plunge recently :lol: )
 Post subject: Re: 64 bit
PostPosted: April 23rd, 2015, 2:24 pm
Media player integration? My info panes for iTunes still work on my 64 bit system no problem. I don't have widgets that use drag/drop but I don't see why they would be broken. I can drag and drop stuff to xlaunchpad no problem though.
PostPosted: June 9th, 2015, 4:44 am
iTunes is connected in a more "architecture-independent" way using IPC sockets and pipes. Doesn't work great with Windows Media Player
PostPosted: April 18th, 2016, 5:16 am
Update re: Win 10 64bit - no problems with the WMP integration here.
