 Post subject: WindowZPosition bug
PostPosted: February 23rd, 2015, 5:25 pm
This code should change z-order every two seconds. But it does this only once.
function datetimecore1OnUpdate(Sender)
  if (widget.WindowZPosition >= 1)
    widget.WindowZPosition = -1;
    text1.Text = "Bottom";
  else
    widget.windowZPosition = 2;
    text1.Text = "Top";
testZPosition.xwp [6.44 KiB]
Downloaded 636 times
 Post subject: Re: WindowZPosition bug
PostPosted: February 24th, 2015, 11:05 am
I can't help you with the script but I think you should use the "timercore" instead of datetimecore...
PostPosted: February 24th, 2015, 1:15 pm
If anybody else is experiencing this bug I found a "fix". It will cause widget to blink when changing z-order, but it's better than nothing.
    setZOrder(-1);
  else
    text1.Text = "Top";
    setZOrder(2);
function setZOrder(z)
  setZOrder.z = z;
  widget.Hide();  // Blink
  widget.Show();  //
function widgetOnShow()
  if (typeof setZOrder.z != 'undefined')
    widget.WindowZPosition = setZOrder.z;
testzposition(1).xwp [6.53 KiB]
Downloaded 683 times
PostPosted: February 25th, 2015, 12:47 pm
Even the above trick fails sometimes :cry:
PostPosted: February 26th, 2015, 6:25 am
As I told you since you want a function that it repeats every 2 secs I think you should use the timecore core.
Example:
http://jimking.deviantart.com/art/Lazer ... -417202701
PostPosted: February 26th, 2015, 1:19 pm
Right. I could also try setDelay() or setTimeout(). But what it has to do with the bug? Isn't this an off-topic here?
PostPosted: February 26th, 2015, 11:46 pm
I tried your first widget and it seems to work OK every two seconds top / bottom and in front / behind another widget. As you have said the code is executing every two seconds in either method. I can not see the problem.
PostPosted: February 27th, 2015, 5:35 am
I added GIF to OP so anybody could see the problem now.
PostPosted: February 27th, 2015, 7:45 am
Same here ... Couldn't reproduce your case
PostPosted: February 27th, 2015, 8:43 am
Maybe you need to click in another window to see the effect. Btw I have XWidget 1.9.3.1022
PostPosted: February 27th, 2015, 12:47 pm
True, once another window is made active, WindowZPosition = 2 appears to not work. If the widget is made active it works again.
Once it looses the most top position it can not regain it via WindowZPosition, but if set to top most will maintain it with show / hide.
PostPosted: March 30th, 2015, 7:25 am
And this is documented here:
http://docs.xwidget.com/index.php?title ... _functions
bringToFront() sets the Z-Index behind the scenes
