PostPosted: January 17th, 2015, 11:47 am
Hi all, i been having some issues with the Editor, it started after i included a timecore, every time i open the editor cpu usage jumps to 22/28 percent, this only happens with the widget ill attach here, with the rest the cpu usage remains below 6%, the editor starts behaving weird, like nothing works properly, things disappear, buttons wouldn't respond, doesn't refreshes when selecting different objects, i restarted xwidget a couple times, no change, deleted timecore no change either. logged off from windows and back to try again, also no change..Any suggestions?
NAV_BottomMenu_V1.xwp [51.09 KiB]
Downloaded 439 times
-George Carlin
PostPosted: January 17th, 2015, 11:16 pm
Animations sometimes drain the CPU?
Any animations running in the widget?
PostPosted: January 18th, 2015, 4:38 am
Hi digigamer, it has around 5 text horizontal scrolling animations (and intended to have around 60 , i guess thats not gonna work he..) ,the widget is attached. Gonna delete some animations and let you know how it goes.
Edit: Yup, you were right, disabled the animations and went back to normal, all good now. Thanks !
-George Carlin
