PostPosted: December 10th, 2014, 3:11 am
Sometimes when I'm default and icon images, you do not have an image in the background.
Image backgroud is from accuweather
PostPosted: January 11th, 2015, 12:36 am
I do not get this question?
Default images are displayed ONLY when widget is loading and is removed afterwards.
** We use a little trick, by using the same images as default image and background, we achieve an illusion as if our widgets awoke form sleep
PostPosted: January 11th, 2015, 4:53 am
You need to check if ALL the weather images have the same file extension.
If the weather tag code is this for example "wth\${curWeatherIcon}.png" you need to check if ALL images are png.
Epecially when you use .jpg images: "wth\${curWeatherIcon}.jpg"
Check if any of them is .jpeg than .jpg :!:
PostPosted: January 11th, 2015, 11:08 am
Thanks jimking!
