 Post subject: OnDragDrop not working?
PostPosted: November 19th, 2014, 5:39 am
Hi, can anyone confirm OnDragDrop event for an Image works?
I can get OnDragOver to work, but OnDragDrop doesn't seem to fire.
OnDragOver I can MsgBox and display the filename immediately of anything I drag over the Image - but OnDragDrop - nothing.
Thanks.
PostPosted: November 19th, 2014, 5:45 am
Found it, sorry, had to go to the 'Others' section and tick 'accept file dragdrop'.
PostPosted: November 19th, 2014, 6:50 am
Yeap..This can be applied when you work with shortcuts or Recyclebin widgets.
Users browsing this forum: No registered users and 174 guests
