PostPosted: November 16th, 2014, 4:26 pm
When I edit the widget using Xdesigner, the alignment for text comments does not work, that is, I can not the text to righ or left center. the text comment is set to left top as default, but sometimes I would like to align it to center or right center, but it is not reflected to Xdesigner display and activated widget!
PostPosted: November 16th, 2014, 6:04 pm
Using txt component, under "Attributes" tab, use the "Text Align" mini "buttons" to align your text.
You can also use under ""Metrics" tab the "Align" options.
All this work 100%.
