PostPosted: October 22nd, 2014, 11:03 am
Tony is possible to have all the available info in tags from the accuweather server..?
For example, I would like to create a full screen widget like this, but with the current tags/codes is impossible..
I'm not telling that the current tags are not ok, but adding all the rest will bring the weather widgets in a whole new level! ;)
PostPosted: October 22nd, 2014, 4:07 pm
I agree jimking :idea:
PostPosted: October 22nd, 2014, 5:56 pm
OK, I will add all info and tags in AccuweatherCore for XWidget2.0 :)
And I am thinking to add a new weather core that can select weather data source, etc: accuweather/weather.com/yahoo.com
but these websites weather data are not the same ,some of website not support multilanguage,some of website only support 6days forecast...
so I think we need define new weather tags to fit all weather website... It was a painful process
Maybe we can refer to this weather app http://www.htchome.org/en/ , any suggestion? :)
PostPosted: October 23rd, 2014, 4:37 am
Great! I think that the most accurate complete and famous weather providers (except accuweather) are: yahoo.com and weather Channel (http://www.weather.com)
that I'm sure that support a lot languages and forecast for +10 days. ;)
Now, if you talk about the android version there are many weather apps that support multi-weather providers. These three are most famous:
https://play.google.com/store/apps/deta ... rt.weather
https://play.google.com/store/apps/deta ... s.unlocker
https://play.google.com/store/apps/deta ... fulwidgets
PostPosted: January 16th, 2015, 6:12 pm
My regards for those that work in this fantastic program. Excuse me if I write bad because i am from a country of Hispanic speech (CUBA) and its more difficult to my write in english.
If you could help me in the adaptation of your corewheather that i am being about making I will always be grateful.
The point its that here in Cuba we don't have access to internet (only feew), We have a MAN (Metropolitan Area Network) whit around 6000 users and I am the administrator of a portion of them. I whant for example: put a file in my server whit the accuweather once a week and its whidgets refresh their weather from that file, can we do that? can I download that file from some site? can we modify your accweathercore to make the recuest to my server?
