PostPosted: October 12th, 2014, 6:54 am
Guys could you pls confirm if using the "playercontrolcore" and "%volume" to control the player's volume doesn't work in the latest version of XW..? (v1.9.2.903) :?
I try it wilth txt, image(click on) and roundline and nothing of them seem to respond to the command...
(the text recognizes the value but doesn't change)
PostPosted: October 17th, 2014, 4:55 pm
i tested with our old project (CleanPlayer), and it's working,
how do you using it?
make sure you have added the command/function to the Event of object
PostPosted: October 17th, 2014, 5:25 pm
Make a NEW simple project hamid and you will see that it doesn't work..
In the same design, I only replaced it with the general volume control code/commands and worked... :?
The widget is posted days ago but you can test it by yourself..
http://jimking.deviantart.com/art/Techn ... -488056451
PostPosted: October 17th, 2014, 7:29 pm
i have tested it, and it works for me without any problems
but why you have used 2 text objects in each side of roundline?
maybe you wanted one to display value and another % sign?
but it has 0 on the one with % sign,
is it a mistake or it should be this way?
edit:
i have tested it with the VolumeCore,
am i suppose to change it to PlayerControlCore for testing?
edit2:
i have tested it with PlayerControlCore, and it's working,
maybe it wasn't working for you because you didn't add the commands for the PlayerControlCore,
the command for Cores are different:
example:
for VolumeCore, it is: [!DownVolume=10]
for PlayerControlCore, it is: [!VolumeDown] (it will change the volume by 5%)
PostPosted: October 18th, 2014, 12:45 am
There are two txt objects:
- 0% (the bottom text without any tag assigned)
- The (%) txt (that has the corrisponding tag showing the percentage)
edit:
edit2:
example:
I know all this hamid! I added the commands but nothing... I'm not so rookie man!
The fact is that using the playercontrolcore volume % tag, not work for all the 3 objects (the txt recognizes the value but doesn't change, the click on commands to up/down WITH the corrisponding tags (!VolumeDown) don't work, the roundine either)
So something is wrong there.....
btw you have saw my pm..?
PostPosted: October 18th, 2014, 1:22 am
yes, i'll do it later, maybe tomorrow,
so what's the reason for using zero for bottom text? :!:
but that's working for me,
ok, try this one:
techno_hq_player [test] [2014.10.18]1240.xwp [885.56 KiB]
Downloaded 733 times
Note:
the player should be opened when you want to change the volume,
because it couldn't access to the player when it's not opened
(so better to be playing or showing to see it's opened and responding)
PostPosted: October 18th, 2014, 1:51 am
Thanks!!! :D
Is something different, right?
Just part of the design. ;)
Note:
You're right! :o
But I'm 100% sure that I was able to control the player's volume before playback....Hmm
PostPosted: October 18th, 2014, 2:22 am
Thanks!!! :D
yes, it's amazing... :D
and i have seen you have added your name everywhere in widget ;)
You're right! :o
but as you told me before, you have used VolumeCore most of the time for widgets,
am i wrong?
edit:
i have found it here: ;)
http://bbs.xwidget.com/viewtopic.php?f=8&t=4744#p9063
and also you have told me before (in CleanPlayer Project) that it always automatically starts playing when you start the widget,
so maybe because of this, you have never seen this before
PostPosted: October 18th, 2014, 2:41 am
I added a right click option so the message on the sign can be customized! ;)
I made it with a little trick using the shortcutcore instead of "edit" object
1) I didn't want it editable on mouse click
2) There is the possibility to add a click on command/shortcut..
You're right! :o
am i wrong?
To be honest I started using the player's volume control after your first suggestion but I made some player widgets since then and I don't remember this "bug" before..
Maybe....
PostPosted: October 18th, 2014, 3:48 am
just to note, it can also be done using promptbox, but promptbox is a simple box
maybe it's not a bug, since the core couldn't control the player when the player not loaded yet,
but it also can be treated as bug if we decide to load the player at startup of widget, maybe better to have a option to start the player on start of widget
it doesn't start the player by refreshing the PlayerControlCore,
it will only start the player if a request is send to player (like stop,pause,loop,shuffle,...),
so as another solution, you can add a command to do one of these on start of widget,
but maybe better to wait for this option to be added to the core
PostPosted: October 18th, 2014, 4:22 am
Yes, I agree....
Doesn't matter hamid. Just leave it as now..
If you can add the checked function for the right click options will be enough already.! :)
