PostPosted: October 3rd, 2014, 6:53 am
Why does not the measurement CPU??? Image Image
https://pp.vk.me/c618820/v618820502/198 ... GKXQz8.jpg
https://pp.vk.me/c618820/v618820502/198 ... 5VdumQ.jpg
PostPosted: October 3rd, 2014, 7:07 am
Download the "TechBall Widgets" from here and test.
http://jimking.deviantart.com/art/TechB ... -363548528
IMPORTANT: Be sure that you have the LAST VERSION OF XWIDGET installed..!
The widget are tested and ALL work properly.
PostPosted: October 3rd, 2014, 7:46 am
I checked @vanya787 and I didn't find anything wrong.
- Try to restart XW from the icon tray
- Be sure that you have the latest version of XW v1.9.2.903
http://xwidget.com/
Have to tried other cpu widgets..?
PostPosted: October 3rd, 2014, 7:48 am
this is your widget, did not help me, what's the problem???? Image
PostPosted: October 3rd, 2014, 7:53 am
http://xwidget.com/
tried to reinstall and set these widgets do not help
PostPosted: October 3rd, 2014, 10:20 am
Try the things that I told you. :!:
Delete and re-install the widget doesn't make any sense!
- Try other cpu widgets like these:
http://jimking.deviantart.com/art/Real- ... -437738044
PostPosted: October 3rd, 2014, 10:28 am
I v 1.9.2.903, I deleted all ustanalival again, but it did not help
PostPosted: October 3rd, 2014, 11:07 am
questions:
1. what's your cpu speed? (maybe it have so much power and doesn't use any percent!)
2. are you testing by making a high cpu usage?
3. is it multi-core or single-core? (have you tried it with core percents?)
4. are you having this problem before or it's just happening right now?
PostPosted: October 3rd, 2014, 12:22 pm
processor: amd athlon (tm) ii x2 240 processor 2.80 GHz
This widget is used to work, then stopped...
PostPosted: October 3rd, 2014, 1:33 pm
maybe i couldn't help more, but you can try these:
1. restart your system
2. make sure you're running Xwidget and Designer with Administrator privileges
you can also try this widget for testing:
cpu_test [2014.10.04]0108.xwp [6.89 KiB]
Downloaded 641 times
questions:
1. have you updated Xwidget recently?
2. have you tried an older version?
3. have you changed anything in your system (OS) recently?
