PostPosted: September 11th, 2014, 10:24 am
Hi.
My suggestion is to create a taskbar like Samurize.
I'm leaving the Samurize because this bar does not work on windows x64.
As shown in the image below.
Thanks.
PostPosted: September 12th, 2014, 8:04 am
Sorry,XWidget can not do this in current version.
Tony
PostPosted: September 12th, 2014, 8:18 am
Tony is possible in version 2.0?
PostPosted: September 12th, 2014, 9:17 am
as a temporary solution,
you can:
1. create a small widget,
2. make it [Keep TopMost],
3. place it in the empty area of taskbar
but you should manage that empty area yourself,
because taskbar items can get behind your widget,
also you can create an empty area by creating an empty toolbar and size it as your widget,
in this case, it can still happens to tray-icons to get behind it,
but i don't think tray-icons change more often
PostPosted: September 12th, 2014, 9:20 am
I will try to develop after XWidget2.0 released
PostPosted: September 12th, 2014, 9:22 am
Thank you so much.
PostPosted: September 12th, 2014, 9:26 am
you can:
Thanks.
