PostPosted: September 1st, 2014, 4:02 am
Xwidget 1.9.1.402
it will be good to have:
widget's RightClick menu, or at least [Window] menu of each widget, in the [Manage Widgets],
since all the running widgets are available there and it could be very helpful to have access to all the Settings of each widget from there.
it could be simply done by adding a RightClick option as Widget's Menu and having RightClick menu of widget in its SubMenu
