PostPosted: July 13th, 2014, 11:17 am
I have a strange problem. All your widgets do in the same way for the PC, but some packing my phone does not want to unpack. I get the message "No application can not open this file" even though I have installed on my phone Xwidget.
I did reinstal and instal many times. Nothing helps.
What could be wrong?
PostPosted: July 14th, 2014, 12:47 am
You pm on DA:
I do widgets on the PC. Then I was getting into, and transfer via USB cable or Bluetooth to my phone. Some of the widget can be unpacked and some writes that "No application can not run this file".
That's why I add a folder and not xwp
On a PC, all xwp work.
I have no idea where the problem is. Always do everything the same. : (
From your words I can understand that you don't follow this procedure.
viewtopic.php?f=18&t=3776
..but you transfer directly the .xwp file in your phone using bluetooth/usb.
1) You put the .xwp into the phone's XWidget folder and then press on the file to install as it should?
(I don't do this way)
2) YOU HAVE TO FOLLOW the procedure from the link to make the things work properly!
3) The instructions are clear:
With the phone connected to the pc, open the XWDesigner, Edit a widget that you want to use in your phone.
Press the "Android Mode" button and then "Send to phone" to install the widget in your device.
The widget will be showed automatically in the widgets' list. You can modify the widget in real time. Adding the widget on your phone's homescreen, making changes in the Designer and each time that you press "Send to phone" you will see your edited widget changes in real time!
Follow the insructions and you will NOT RECEIVE any error...Trust me!
PostPosted: July 15th, 2014, 3:05 am
Thank you. I'll try your way and write if it works for me.
