PostPosted: July 11th, 2014, 7:24 am
Xwidget 1.9.1.402
it will be good to have an option in designer or on every widget to choose between:
1. Running Normally
2. disable widget on hide widgets
i mean:
shutdown that widget on hide event and run the widget on show event
this way we could make Visual-Only widgets to don't run when they are hidden
because the Visual-Only widgets are working to show something on screen and doesn't have anything to do when they are hidden
so the cpu usage will be lower this way
