Post new topic Reply to topic  [ 15 posts ]
PostPosted: May 18th, 2014, 11:12 am
Just this morning I've encountered a weird issue with the weather data only partially updating on Android. The below image (from a previous thread: viewtopic.php?f=3&t=4270) illustrates the issue:
http://bbs.xwidget.com/download/file.php?id=3059&mode=view
Here's what I'm observing:
  • The current Wind Speed and current short description (eg, "Cloudy" in the above image) are both coming through fine on Android (though I'm not 100% sure that the Wind Speed data is correct). But temperatures, etc. are not. The few pieces of data that are being displayed do change over time, so data is being pulled down from the server.
  • One thing that is interesting about the above is that the variable that is working correctly (ie, "${curSimpleWeatherIcon}" returns a word value. I don't know which Wind Speed variable is used in the Detail screen (and which seems to be returning a value), but perhaps it is one which contains letters as well? This makes me wonder if the potential bug in Android XWidget has to do with the weather variables that are numbers?
  • This problem is on two different Android devices, but my Windows 7 desktop pulls down (and displays) all the weather data just fine. So it seems like the weather server is working just fine.
  • I've tried re-adding the widget in Android but it doesn't make any difference.
  • I also tried adding a different widget in Android, but the result is the same.
  • Rebooting my Android device had no effect either.
Any thoughts on what might be going on?
Also, I would suggest that the backend code somehow check for the validity of the weather data, and not purge the old data until it believes the new data is complete, etc. I would rather still have yesterday's data (and least be able to see future days [as of yesterday]) than ending up with basically no usable data at all.
Thanks for any help!
PostPosted: May 18th, 2014, 11:27 am
This is an isuue with the communication with the accuweather server.. So it's up to their servers, it's a temp problem and it will be resolved soon. Some times happened to the pc version too. The dev fixed this with the latest version, but seems that on Android uses a different mechanism..
PostPosted: May 18th, 2014, 11:43 am
What's weird though is that some data is being pulled down and displayed, so it's not a total breakdown in the connection (and it can't be a server failure since the Windows version is pulling the correct data down for the same location at the same time). So is it that the Android app somehow fails at accessing all the server data (ie, it gets stuck on most of it, but is able to pull/parse a small portion)?
Also, if you could flag/forward my feature request to the dev that would be awesome:
I understand that hiccups are going to happen with accessing the weather data (eg, the stock Samsung weather widget on my tablet went through a period where it would get stuck for days!), but it would super-helpful if XWidget kept the previous data instead of replacing it with mostly-empty data.
Thanks! :)
PostPosted: May 18th, 2014, 12:10 pm
The dev is working to fix all these issues. So pls wait for the next version..
PostPosted: May 18th, 2014, 12:54 pm
Awesome! Thanks! :D
PostPosted: May 19th, 2014, 4:31 am
I just wanted to report (for others' reference you may encounter this issue at some point) that my weather data returned to normal today. :D
PostPosted: May 19th, 2014, 10:58 pm
hi, my weather temp still half missing :'(
PostPosted: May 20th, 2014, 1:03 am
Try to update manually. The weather data works from yesterday..
Sorry guys for this issue. The dev is working on this..
PostPosted: May 20th, 2014, 3:29 am
it's 5:27 am mountain standard time and the weather us back to normal looks like there's working as good as new ;) thanks
PostPosted: June 17th, 2014, 12:41 pm
Temperature data hasn't been coming through all day (17 June) here in the UK, nor have weather forecasts beyond the current day, although it was all working fine for the Android app yesterday evening. Has this communication problem with Accuweather started again?
PostPosted: June 17th, 2014, 2:37 pm
Yeah, I'm seeing the same thing. I'm in the US. It'll probably resolve itself within the next 24-48 hours. It's annoying though.
PostPosted: June 17th, 2014, 10:31 pm
All work fine again..
PostPosted: June 18th, 2014, 1:44 am
Thanks, jimking - yes, working again here today!
PostPosted: June 18th, 2014, 4:14 am
Me too! :)
PostPosted: June 18th, 2014, 9:23 am
I'm from Poland.
I have a strange problem on my Android phone. No temperature conditions etc.
http://www.bankfotek.pl/image/1743188.jpeg
http://www.bankfotek.pl/image/1743189.jpeg
On the PC is OK
The problem arose this morning.
Users browsing this forum: Bing [Bot] and 212 guests
