 Post subject: Trojan.ADH.2
PostPosted: April 18th, 2014, 1:43 pm
XWidget Version: 1.90
Norton Antivirus say it contain a virus when I download it from the link on http://www.xwidget.com
Trojan.ADH.2
Discovered: August 30, 2010
Updated: November 7, 2013 11:22:15 AM
Type: Trojan
Systems Affected:
Windows 2000, Windows 7, Windows 95, Windows 98, Windows Me, Windows NT, Windows Server 2003, Windows Server 2008, Windows Vista, Windows XP
Trojan.ADH.2 is a detection technology designed to detect entirely new malware threats without traditional signatures. This technology is aimed at detecting malicious software that has been intentionally mutated or morphed by attackers.
Antivirus Protection Dates
Initial Rapid Release version August 30, 2010
Latest Rapid Release version April 15, 2014 revision 023
Initial Daily Certified version August 31, 2010 revision 002
Latest Daily Certified version April 15, 2014 revision 025
Initial Weekly Certified release date September 1, 2010
Threat Assessment Wild
Wild Level: Low
Number of Infections: 0 - 49
Number of Sites: 0 - 2
Geographical Distribution: Low
Threat Containment: Easy
Removal: Easy
Damage
Damage Level: Low
Distribution
Distribution Level: Low
http://www.symantec.com/security_response/writeup.jsp?docid=2011-030906-0727-99
 Post subject: Re: Trojan.ADH.2
PostPosted: April 18th, 2014, 2:26 pm
Thanks for the report. This is a known matter though..
Please read all these:
viewtopic.php?f=3&t=4366
viewtopic.php?f=2&t=2
Don't worry! XWidget is 100% clean.
PostPosted: April 19th, 2014, 5:29 pm
May be due to ads or the function isKeyDown().
This is a hook that XWidget puts in system, I've an active firewall running and through all my observations, XWidget doesn't transfer any such data. It's definitely not a kind of trojan.
And don't trust ADH system of Norton.
Once in my school days I was writing a program that loaded a dll, and called a function that pops up a message box, so simple code... and believe me the ADH system sounded an antivirus alarm and being in school... you know, I had a hard time to explain...
