PostPosted: March 24th, 2014, 1:15 am
I noticed that the sun and moon rises and sets are in 24 hr format.
how can you set those times to be in 12 hr?
PostPosted: March 24th, 2014, 1:43 am
I wanted to but I'm afraid that we have to wait for the next version of XWidget. I hope that the Dev will add new tags for this..
Like the 12h for the weather's update time..
PostPosted: March 27th, 2014, 3:35 pm
if you familiar with scripting you can do this with a little scripting:
just you need to split hh:mm by ":" to get the hour from it and change the hour to 12hour and recreate the hh:mm format:
example:
//need to create text1 Object
//need to have accweathercore1 in widget
//don't forget to add [datetimecore1OnUpdate] in the [OnUpdate] Section of datetimecore1 in designer
function datetimecore1OnUpdate(Sender)
  tmp1=accweathercore1.get("%sunSet").split(":")
  if(tmp1[0]>12)
     tmp1[0]=tmp1[0]-12
     text1.Text=tmp1[0]+":"+tmp1[1]+" PM"
  else if(tmp1[0]==0)
     text1.Text=12+":"+tmp1[1]+" AM"
  else if(tmp1[0]==12)
     text1.Text=12+":"+tmp1[1]+" PM"
  else if(tmp1[0]<12)
     text1.Text=tmp1[0]+":"+tmp1[1]+" AM"
PostPosted: March 27th, 2014, 4:09 pm
Good hamid! ;)
I continue to believe though that if Tony add a tag for this on the next version, will be more simple for all. :)
PostPosted: April 3rd, 2014, 3:52 pm
I did scripting. I had to modify to strip the 0 from the sunrise
//sunrise
  tmp1=accweathercore1.get("%sunRise").split(":")
  if(tmp1[0]>12)
     tmp1[0]=tmp1[0]-12
     sunrise.Text="Sunrise: "+tmp1[0]+":"+tmp1[1]+" PM"
  else if(tmp1[0]==0)
     sunrise.Text="Sunrise: "+12+":"+tmp1[1]+" AM"
     sunrise.Text="Sunrise: "+12+":"+tmp1[1]+" PM"
  else if(tmp1[0]<12)
     if (amhour=tmp1[0].split("0"))
     sunrise.Text="Sunrise: "+amhour[1]+":"+tmp1[1]+" AM"
     else
     sunrise.Text="Sunrise: "+tmp1[0]+":"+tmp1[1]+" AM"
//sunset
  if(tmp1[0]>12)
     tmp1[0]=tmp1[0]-12
     sunset.Text="Sunset: "+tmp1[0]+":"+tmp1[1]+" PM"
  else if(tmp1[0]==0)
     sunset.Text="Sunset: "+12+":"+tmp1[1]+" AM"
     sunset.Text="Sunset: "+12+":"+tmp1[1]+" PM"
  else if(tmp1[0]<12)
     sunset.Text="Sunset: "+tmp1[0]+":"+tmp1[1]+" AM"
PostPosted: April 3rd, 2014, 4:25 pm
edit:
i didn't noticed that you have done with removing 0 from it,
so have this one as another way;
and some tips:
i forgot to tell, you can also use [accweathercore] for update instead of [datetimecore];
(to lower the resource usage)
just added this line to previous code, this will convert the string to integer:
tmp1[0]=parseInt(tmp1[0],10)
here's the full code:
//sunrise
  tmp1[0]= parseInt(tmp1[0],10)
  if(tmp1[0]>12)
     tmp1[0]=tmp1[0]-12
  else if(tmp1[0]==0)
  else if(tmp1[0]<12)
//sunset
  if(tmp1[0]>12)
     tmp1[0]=tmp1[0]-12
  else if(tmp1[0]==0)
  else if(tmp1[0]<12)
