 Post subject: new version = new bugs
PostPosted: March 18th, 2014, 4:18 am
:evil: SUPER BUG!
* Creating button... Link it to the shortcutcore... Testing... It doesn't works!
* Loading previously maded widget with buttons... Works!
:geek: STRANGE BUG! (why&)
* Created widget moving not allowed by default.
:( SAME OLD BUG!
Animation effects enabled but not works (needed to script manual editing)
Image~ELECTROSELF~
PostPosted: March 18th, 2014, 5:51 am
Could you pls be more specific dezinto?
I have the latest version 1.1.8.1106, I already made a LOT widgets and I don't have any of these bugs that you report...! :!:
All work and are tested. Are you sure that you don't forget "something"?
PostPosted: March 18th, 2014, 7:47 am
Thanks for your feedback, the shortcutcore bug I had fixed and uploaded, please re-download the last version of XWidget from XWidget.com and overWrite install to update.
PostPosted: March 19th, 2014, 2:51 pm
Thank You. Shortcutcore is fixed and now works fine.
Image~ELECTROSELF~
