 Post subject: screen capture
PostPosted: January 6th, 2014, 12:00 pm
is it possible to be made a button that can take a capture of the screen???
 Post subject: Re: screen capture
PostPosted: January 6th, 2014, 2:04 pm
Right click on a widget ->Window-> Functions-> Screenshot
PostPosted: January 6th, 2014, 2:37 pm
sorru i wasn't cleared... i meant a screen capture of desktop as prtscn does
PostPosted: January 25th, 2014, 7:54 pm
Not possible using standard procedures. However you can create an executable that does this for you and invoke it when required
PostPosted: January 26th, 2014, 2:38 am
ok thanks
PostPosted: January 27th, 2014, 12:01 am
Do you mind if I ask what you want to do with the screen capture once it is on the clipboard ?
PostPosted: January 27th, 2014, 3:16 am
Guys don't make your life difficult.. I use it for years:
http://www.faststone.org/FSCaptureDetail.htm
(you can find the patched version easily on the net)
PostPosted: January 28th, 2014, 12:53 am
I think he's interested in creating a screen capture widget?
PostPosted: February 6th, 2014, 12:53 am
i used hypersnap but i though it somedifficult in use... i get a look of faststone thanks anyway for help
Users browsing this forum: No registered users and 168 guests
