 Post subject: netmonitorcore
PostPosted: January 2nd, 2014, 9:49 am
netmonitorcore does not show my data ... I'm using 3g usb modem connection ...
 Post subject: Re: netmonitorcore
PostPosted: January 2nd, 2014, 9:58 am
You have this issue only with low values or in general? I'm not sure but maybe the netcore supports only wifi/ethernet standard connections (?)
(Please be sure to have the latest version of XWidget installed.)
PostPosted: January 2nd, 2014, 11:09 pm
I'm using the latest version ... and why not b developer to add support ... Other programs operate in
PostPosted: January 3rd, 2014, 2:38 am
I don't understand what do you mean.. Tony and qiancang can help you for sure. Please wait for their reply or the next version of XWidget.
PostPosted: January 4th, 2014, 8:15 am
OK
PostPosted: January 25th, 2014, 7:51 pm
USB Modems DO NOT (and probably never would) work with the netmonitor. Even windows doesn't have any standard procedure for getting these data from. I've searched till the end of the world but could never find any info on it.
PostPosted: January 29th, 2014, 8:44 pm
do you use windows connections to connect to the internet?
or
do you use direct connection through modem [Bridge] (your connection is saved in your modem)?
