PostPosted: December 31st, 2013, 1:46 pm
To some of you guys happens something like that: I can not edit "Custom tooltip". I press the button and nothing happens ... What can be happening?
PostPosted: January 7th, 2014, 12:30 am
If you use version 1.8.8.1111 (at the moment the latest from the xwidget.com webpage), the tooltips feature in Xwidget Designer is partially broken. You could try to use an older version (e.g. 1.8.8.1106) of XWDesigner.exe (that's what I did to solve it). See also: viewtopic.php?f=3&t=3779.
