PostPosted: December 29th, 2013, 6:35 am
I occasionally get the following error in the Event Viewer just after Xwidget crashes on start-up of my computer. This does not happen very often but I would like to investigate and document it for a possible bug fix.
Faulting application name: xwidget.exe, version: 1.8.8.1025, time stamp: 0x2a425e19
Faulting module name: xwidget.exe, version: 1.8.8.1025, time stamp: 0x2a425e19
Exception code: 0xc0000005
Fault offset: 0x000085b8
From what I have found out is that Exception code 0xc0000005 is an Access Violation.
Is there a way to capture debug logs (possibly also starting the executable in a debug mode) to find out what is causing this crash.
PostPosted: December 29th, 2013, 7:37 pm
I also experience crashes on startup, as you said not very often, my be one in 30 or 40 starts.
Log Name: Application
Source: Application Error
Date: 03/01/2014 06:37:09
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Description:
Faulting application name: xwidget.exe, version: 1.8.8.1030, time stamp: 0x2a425e19
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Fault offset: 0x03af6c55
Faulting process ID: 0xe54
Faulting application start time: 0x01cf07f1eac09535
Faulting application path: C:\Utility\XWidget\xwidget.exe
Faulting module path: unknown
Report ID: 4464d74b-73e5-11e3-b168-000c761a0a5e
PostPosted: January 25th, 2014, 7:55 pm
You need a debugger (such as Visual Studio) installed. You'll also need symbols for XWidget to start it in debug mode. However, there is nothing much you can do using debug as XWidget is CLOSED SOURCE
