PostPosted: December 6th, 2013, 12:24 pm
When I use an image with the "Aero Blur (Vista/Win/7/8)" enable, when I resize the widget on desktop, the aero blur effect not change its size... :(
I'm missing something..?
Also when I try to hide this image through script
image1.Visible = false;
the image is still there....
There is a way to turn off the "Aero Blur" option with a script? :?
PostPosted: December 7th, 2013, 12:47 am
try refreshAeroBlur()
PostPosted: December 7th, 2013, 5:04 am
Thanks DG! I found a different solution though, but I will keep it in mind for the next time.. :)
Users browsing this forum: No registered users and 168 guests
