 Post subject: Can't install
PostPosted: November 17th, 2013, 9:10 am
Hello!
Why can't install from the xwidget gallery??
I push the button, pop up the xwigdet gallery, I choose an widget, push the download, and nothing...
If I can download any site widget, Don't install pkg file it. Why?
(Win7 x64)
 Post subject: Re: Can't install
PostPosted: November 17th, 2013, 12:19 pm
Hello gadgetk.
You mean this?
viewtopic.php?f=3&t=3634
If you have this problem this happens with Firefox.
About the download you need to press this button:
Be sure that you have the last version of XWidget installed:
http://xwidget.com/
To install any widget just double click on the file package.
PostPosted: November 17th, 2013, 5:48 pm
Yess yess. It was No latest version... I download it, and everything ok!
Thanx man!
