PostPosted: November 1st, 2013, 10:00 am
XWidget:
1. Assigning HotKeys for all RightClick Menuitems
>Easier Navigation & Customization
2. Display HotKeys infront of Menuitems
>Help to don't forget HotKeys
XWidget Designer:
1. Script AutoComplete Menu Only by Pressing Ctrl or Alt
>[Ctrl+D] is difficult; it need a Simple & Handy Key; i don't think Ctrl Key Assigned to Something, also Alt is unused because there is no menu in the Designer
2. Script AutoComplete Button on the Top in the leftSide of Functions List
>with mouse it is difficult to always RightClick & choose AutoComplete
3. Button for Create Default Image & Widget Icon from Debugger
>By Automatically generate Image, it only generate Current State of Widget without Script Execution
4. Selecting Multiple Objects & See or Change Common Options of them
>So Helpful when you have added and Organized too many Objects and want to change an Element in All of them
5. Right Click an Object and get Properties from another Object
>Same as 8.
6. get properties from Another Object on any Element of Properties (Inspector)
>it's useful to have a Button on any element of Properties in Inspector that by Pressing it See the list of Objects and Select one to get properties of the Element from that Object
7. Splitter Line in the Menu Editor
>menus will get more Organized
8. add FullScreen Command for Objects
>Useful to Toggle Fullscreen of any Object (Image, Text, Graph,...); Specially for Images
9. Player Core (for Audio/Video Playback)
>Creating fully Customizable Player for Everyone; that will be Awesome
10. Inspector View Always Visible in the Code View
>Accessing Properties always Needed when Coding
11. Minimize/Restore Button (like on the top of Libraries View) on Any View of Designer (Design, Code, Inspector, Log,...)
>Make Customization Easier when temporary need more Space on Screen
12. On changing of the Design,Code,Log,Split; instead of Hiding the Other Views, Minimize Other Views
Users browsing this forum: Bing [Bot] and 212 guests
