It is currently October 23rd, 2026, 8:21 am
PostPosted: September 28th, 2013, 2:57 am
Hi Xwidget Developers! I have, and not only me, this bug:
Bug is that the songs that don't have a cover, cover from other song. This is also with the songs that have covers (1-2 songs),
I even did not see the image "No Cover" on the songs without covers.
I hope you quick fix this.
Best regards, RaDMaN.
PostPosted: September 28th, 2013, 3:10 am
Hello RaDMaN. Have you tried other player widgets..?You can use the "Search Cover Tool" (if the developer of the widget added the right click menu). I'm not 100% sure but you can try..!
PostPosted: September 29th, 2013, 12:08 am
Hello! Yes:
Search Cover? If necessary, I myself can add a cover for the song. That still does not solve the problem. In older versions of XWidget this was not.
PostPosted: October 2nd, 2013, 6:48 am
I'm sorry, Tony, but yoy fix this in next versions XWidget?
PostPosted: October 3rd, 2013, 12:34 am
That is a well known bug of XWidget. "JPG Error #53: Image too large". Orrurs when partially distorted image or very large ones are used for images. Changing the cover and refreshing the Cover cache will fix it. Be sure to keep the image within some kilobytes and 800x600 px. Change the image and delete the contents of the folder %USERPROFILE%\Documents\xwidget\Data\Covers Then reload the widget.
PostPosted: October 4th, 2013, 4:14 am
pass-4sure.me.uk
http://www.ibm.com/us/en/
http://www.stanford.edu/
http://en.wikipedia.org/wiki/IBM
PostPosted: October 9th, 2013, 1:35 am
Hi, blackrose! Yes, see screenshot on the top.
"Search Cover? If necessary, I myself can add a cover for the song. That still does not solve the problem. In older versions of XWidget this was not."
digigamer covers in jpg, and 600x600 all.
PostPosted: October 9th, 2013, 7:54 am
Not strange though. This issue appears randomly in my widgets too. And these days more frequently.
** Had a look at what's happening and found XWidget in its latest version is generating bad image files. It has an additional byte(s) of text data before the actual image data. Bug confirmed!
TONY: PLEASE FIX THIS ASAP!
PostPosted: October 10th, 2013, 2:35 am
I just found this microsoft update and it solved some of my image-related issues:
http://support.microsoft.com/kb/2836502
But before that check if it is already installed!
PostPosted: October 27th, 2013, 1:58 am
This is not fixed in Version 1.882013.10.25, Tony, please fix.
Users browsing this forum: No registered users and 149 guests
