 Post subject: Prevent from closing.
PostPosted: September 25th, 2013, 1:39 pm
Hello, I made the same post in the help section first and I was suggested to post it here so this is pretty much a copy paste of my 1st post.
I am new to this XWidget and I found it awesome, Im just trying it, however I am having just one problem with it that is, whenever I press ALT + F4, it closses D:
How can I make it not to do that, this command I always use it to close a lot of things so I accidentally press it a lot, or to turn off the computer, plus I have another widget that doesnt close when ALT + F4 is pressed, so, is there any way, if not, is there any way to make it possible. I have tried all the options in the program and different configurations and widgets still close when ALT F4 is pressed.
Thank you for any answer or help.
