 Post subject: Bug? in calendar core
PostPosted: July 26th, 2013, 6:14 am
When display the month which the 1st day of the month is sunday, the first row of calendar becomes blank.
For example, the 1st day of this September is sunday, and so the extra row appears in the first row!
PostPosted: July 26th, 2013, 6:54 am
Could you pls provide a screenshot? Because there two modes that a calendar works, that depends from the design.. (show near month days on/off)
PostPosted: July 26th, 2013, 12:42 pm
Here post snapshot!
(http://www.xwidget.com/xwidget/widgets/ ... 3/345.html)
PostPosted: July 28th, 2013, 3:05 am
That's normal macchan0707. This calendar was made with the "show near month days off" mode.
If you want to change it manually:
Right click on the widget->Edit
On the left click on the "cal1" (the calendar component)
On the right open the "Calendar Settings" enable the "show near month days". From there you can adjust the opacity of these digits. For what you want put it to 100%.
That's all! ;)
PostPosted: July 28th, 2013, 5:10 pm
I just mentioned about the case of non "show near month days" (mostly used in this case), in that case the first week become blank!!!
