 Post subject: Curve Text?
PostPosted: May 15th, 2013, 11:54 am
Tony it will be awesome if you can add an option to change the curvature of the text (in the "Format" submenu) so we will can create semicircle or even circle texts! ;)
Thank you
 Post subject: Re: Curve Text?
PostPosted: May 15th, 2013, 4:49 pm
There's a widget that does this through extensive repositioning and rotation ... that's by qiancang. It is here...
http://bbs.xwidget.com/viewtopic.php?f=11&t=2317&p=3033&hilit=circle&sid=828c60e19fb8c7e5458b536772955b49#p3033
Note: The widget is CPU intensive! :!: And you have to adjust the length for every string you want to display. :D
PostPosted: May 15th, 2013, 5:00 pm
Thanks DG but a single option IN the Designer with rotate angle selection it will be more easily!! :lol:
PostPosted: May 15th, 2013, 5:18 pm
Ya... agree to it +1... I second you in this suggestion!! :D
PostPosted: May 16th, 2013, 7:36 am
I would love this option too!
