 Post subject: FONT BUG!
PostPosted: April 30th, 2013, 11:39 pm
Tony could you please check the font function in Designer? I received complaints from users that the font that I used (and works for me) is not appears correclty in their pcs. This means that the Designer is not memorized the font or something wrong with the windows fonts and XWDesigner...
 Post subject: Re: FONT BUG!
PostPosted: May 1st, 2013, 4:00 am
I traced your issue from dA (I was going to file a bug). I dissected your widgets "main.xul" and saw that you use a font 'Digital-7'. That was not displayed in the designer.
It is not an issue with XWidget. The real issue is with your coding. You have selected the font in Font list (it appeared since the font was installed in your pc). Instead you should use 'Custom Font File' and set the file to your font since it is a non-standard font.
NOTE: After Installing the font from the link you gave works fine.
