PostPosted: April 28th, 2013, 6:17 am
functions FolderExists() and FileExists() causes an error "Insert disk in drive X:", when check an empty dvdrom. I don't know, is this a bug, but it causes problems
I've tried to use DiskIsReady("") function, but I didn't understand, how to use it.
PostPosted: April 28th, 2013, 5:27 pm
This isn't a bug. That's standard windows practice. If some drive is not ready, no API operation is allowed on it.
if(DiskReady("DRIVE:"))
//some  stuff
else {
//disk not ready
For more control, you can use file system object. See MSDN for more details
PostPosted: April 29th, 2013, 10:10 pm
When I use DiskIsReady("Drive:") function, it cause an error "Runtime error: the existence of an object is expected" (Translated from Russian)
PostPosted: April 30th, 2013, 3:08 am
Hi, you can uses the DiskCore, and set disk name with
diskcore1.cmd(null, "diskname=c");
  if(diskcore1.IsBlank)
      //the disk is blank or not exists
  else
if(diskcore1.DiskType<2)
  alert("disk not exit");
Or, you can use ActiveX object "FSO" function "DriverExists" and get the disk type
var fso = new ActiveXObject("Scripting.FileSystemObject");
if( ! fso.DriveExists("d") )
  alert("Dirver D is not Exists");
PostPosted: April 30th, 2013, 8:56 pm
Ok... As I expected..
then this is what you need
http://msdn.microsoft.com/en-us/library/x681abd9(v=vs.84).aspx
var disk = fso.GetDrive("J:"); //change with your drive
if(disk.IsReady)
//disk is ready and contains media
else {
//disk not ready...
I don't know why but I too faced problems with XWidget built-in DiskIsReady(). This is a bug... needs to be fixed. Meanwhile ActiveX is the only workaround.
