 Post subject: CPU cores
PostPosted: April 21st, 2013, 5:26 pm
Tony I see that when is not available a cpu core, when I use the code,for core that not exists 2,3,4 , appears like this "%CPU3". Maybe you should fix this and it will better and less ugly show as "0%"....
 Post subject: Re: CPU cores
PostPosted: April 22nd, 2013, 4:51 pm
OK, I will fix this next version ,thanks :)
PostPosted: April 23rd, 2013, 6:23 pm
My best solution is to place the format code in Substitute too (if you are using a text control) or manually update by registering a listener in core.onUpdate for other component. Example place '%CPU3" in substitute while %CPU3" is your binding core format.
Tony, this too needs to be fixed in many other cores too. I've seen this problem in RSS and GMail cores. Perhaps, they should return 'undefined' (script convention) or a blank value.
