It is currently October 23rd, 2026, 7:30 am
 Post subject: Windows info code?
PostPosted: April 21st, 2013, 2:39 pm
Tony,I would like to ask you if there is a code that shows info about the windows installed for example:
"Windows 7 Ultimate 32-bit version xxxx service pack 1"
It'll be great if you can add these info in the next version...
 Post subject: Re: Windows info code?
PostPosted: April 25th, 2013, 6:21 pm
OK, I will add this in next version as tags of RAMcore
PostPosted: April 29th, 2013, 5:38 pm
Obviously there is existing code to this...
This is in JS
var Computer = "."; //set to any computer you want to retrieve info "." for local computer
var wmi = GetObject("winmgmts:{impersonationLevel=impersonate}!\\" + Computer + "\root\cimv2");
var os = new Enumerator(wmi.ExecQuery("Select * from Win32_OperatingSystem"'")).item();
print(os.Caption); //do something
here is some more detain on additional properties
http://msdn.microsoft.com/en-us/library ... 85%29.aspx
PostPosted: April 30th, 2013, 3:46 am
Thanks digigamer! I will try to use these... :)
Users browsing this forum: Bing [Bot] and 211 guests
