 Post subject: RSS is working???
PostPosted: April 20th, 2013, 3:32 pm
Tony could you pls check if the rss code works properly? I make a rss panel, the links exist because can click on them(the page on net opens normally) but all the text/s are inivisible!!! :!:
I use this for example: http://news.google.com/?output=rss or http://feeds.bbci.co.uk/news/world/rss.xml
Also there is the same problem in the Designer. Sometimes the text appears and any change on the text font or size not work...
---At last I discovered the bug and the solution! There is a bug using the layer component. When you use a layer and into this the rss text/s the texts are not shown! When I pull out the elements from the layer the texts show up normally.. Please fix this!---
 Post subject: Re: RSS is working???
PostPosted: April 21st, 2013, 12:16 am
Hi, I will fix this bug soon
please add a "&" at the end of RSS URL, etc:
http://news.google.com/?output=rss&
