PostPosted: April 20th, 2013, 7:56 am
Tony, some suggestions for next version of "calendar" element:
- add "events" (ability of adding not only "holidays") (I know you can use "custom holidays" to add events, but it's not the same, you can assign a different color, image, ecc.).
- add the possibility of assign an period to this "events" (from 1ยบ july to 8 july).
- add the ability of set if this event is just one time, or is every month, every year, ecc.
Just copy this suggentions in some "to do" list ... ;)
Bye!
PostPosted: April 21st, 2013, 12:23 am
Hi Armando, Thanks, I had copy these in to my TODO list :)
Users browsing this forum: No registered users and 168 guests
