 Post subject: XML dom parser/XPath
PostPosted: April 12th, 2013, 6:26 am
This is infact an issue that I feel is typically unique to me. AAMOF, I access a lot of web services in my widgets and they return data in XML. As I'm from a programming background, I'm addicted to AJAX and DOM in web pages and XPath in applcations. So if you guys can, then please, add support for XPath or DOM for XML. Currently I use regex in my widgets and regex is very cumbersome.
Thanks.
 Post subject: Re: XML dom parser/XPath
PostPosted: April 23rd, 2013, 6:17 pm
Now, this is fixed. I figured out that XWidget uses windows script host. It allowed me to create ActiveX objects.
For those interested how to fix it
var xmlhttp = false;
try {
 xmlhttp = new ActiveXObject("Msxml2.XMLHTTP");
 } catch (e) {
 try {
   xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
 } catch (E) {
   xmlhttp = false;
if(xmlhttp) {
xmlhttp.open("GET", "url_goes_here_", true);
xmlhttp.onreadystatechange=function() {
 if (xmlhttp.readyState==4) {
  var doc = xmlhttp.responseXML;
  //do something with doc
 xmlhttp.send(null);
else {
alert("Fatal Error: Perhaps you don't have MSXML installed");
