PostPosted: April 11th, 2013, 7:13 pm
TONY:
It would be great, in the next version of xwidget:
Add an option like this: the ability of select multiple widgets (maybe with a clic & describe an rectangular area), and then you can move them.
This is useful when you have a lot of widgets (in my situation: notes) and you whan to move at the same time.
Maybe would be nice if you can "group" and "ungroup", some widgets.
Also!... it would be good... the ability of have shorcuts! (i.e. to create some new note!!!!!) it would be fantastic...
thanks!!
