PostPosted: March 20th, 2013, 4:45 am
Tony please fix the "Day of the Year" code.. For example for today 20/3 when selected it shows as "20OfTheYear".... :(
Same happens with "Day of the month" code........
Edit: It will be great if you can give me the right codes for these, because I'm preparing a very interesting widget and this ruins the design..
Thank you!
PostPosted: March 20th, 2013, 6:06 pm
Hi,Thanks, This bug had fixed ,please download this portable version and unzip over write EXE files of XWidget http://www.xwidget.com/download2.php
PostPosted: March 20th, 2013, 8:24 pm
Thank you Tony! I did it and works ok! I'm ready to finish my work now..! :D
Users browsing this forum: No registered users and 248 guests
