PostPosted: March 19th, 2013, 7:34 am
Tony, in next version maybe you can add this Hint's improvements:
- possibility of setting the exact position of hint
- ability to set the delay time to show the hint
- ability to set the time shows the hint
- Realtime update hint (ie. for songs times)
- fade in/out of hint (or other transitions effects... still better ...)
And... some more exquisite settings ...
- ability to set the times that show a hint (maybe after 2 o 3 times you see a hint you are not more iteresed to be showed).
- ability to set that the hint be showed a little bit time after you leave the hinted object
I hope these tips serve you. Bye!
Users browsing this forum: No registered users and 168 guests
