PostPosted: March 13th, 2013, 4:12 am
Tony, in the last version I notice that sometimes the preview/debug funtion is not working properly (and I have to restart XWidget or Designer). It doesn't memorize all the last changes and when run debug the widget is not the same as the preview....
Edit: I notice this happens with roundline. When I use the frag/move/resize with mouse it doesn't memorize the new position/size. Works only when I use the manually "Position & Size" buttons...
PostPosted: March 14th, 2013, 5:02 am
Thanks, I will check this problem :)
PostPosted: June 12th, 2013, 4:55 am
The problem still exists with roundline! When I move it manually using the mouse, the designer does memorize the new position or any modification. Works only if I use the arrows (up and down) next to the values X, Y, Width, Height.
